TIMING CONFUSING
TIMING CONFUSING
today i deside to adjust my timing but i was confusing how to do iy.
what the correct procedure for it.
what i did is put harmonic to tdc 0 degrres, then i put white marker in it to 14 ,warm the engine,remove spout,then timing ligth ,at this step i was confuse ,what should i do ,do i need to bring the 14 deg marker to pointer edge or theres diffrent method .[/align]
RE: TIMING CONFUSING
Follow the steps in this article here. it tells you exactly what you need to do.
that what i do man but when i adjust timing the marker line moving ,clock wise advancing so line marker move toward pointer,,anticlock wise is retard so marker away from pointer.so my target to bring the 14 deg to pointer edge ,is that correct
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
