bad idle-need help
bad idle-need help
i have an 88 mustang and it ws stolen about a year ago and when i got it back from my insurence corp it would some times loop up and down when it was at idle. and it slowly has gotten worse and worse. this year i put an h-pipe with cats on it so i could go through the smog control tests to insure the vehicle for another year. now the car constantly loopsup and down at idle... it stays at 1000 rpm and it dips down and comes back up to 1000 and it does this over and over untill it dips down so low that the car shuts off. sometimes when i comming to a stop the car just shuts off on me.
the car has a new computer, new injectors, new plug wires, new h-pipe with cats, and no other serious problems.... it went through the smog control tests with flying colors. also the car was put on a scope and there seemed to be no problems.
if anyone has had this problem or has any imformation on this it would be appreciated becaue i've spend some moeny on this already and still the rpoblem isn't fixed.
thank you
thank you
RE: bad idle-need help
how much are those tps's? i got like 5 of em layin around.... and if you play with the idle screw, make sure you set the tps last... idle screw will effect tps voltage reading... should be around .98
