installation help
installation help
before i bought my car it had been stolen. and the key ignition was striped so that any key could start it....
i got a new key ignition thingy. any 1 know how to install it or mabey can give me a tutorial on how to do it?
any help would be great....
oh by the way itz a 94 GT
RE: installation help
there should be a hole in the bottom of the plastic shroud around the column. 3 or 4 bolt holes, and 1 smaller hole. turn the key to the ON position, and use a small pick or thin thin screwdriver and push up into that hole. if you use a flashlight, you will see the ball you need to push in. once you push that ball in, the cylinder will pull out.
ORIGINAL: mattdel
09-10-2015 08:39 PM
