back together and ready to try again
RE: back together and ready to try again
ORIGINAL: PRO50SC
Nice, you have a link for the elbow. I can't seem to find it on Summit's site
Do you know if the flow is better then the pro products I run now. Shorter runners so i would think so.
ORIGINAL: PRO50SC
I just called www.coasthigh.com and ordered just the elbow from them.
but here is one on ebay
http://cgi.ebay.com/ebaymotors/New-F...spagenameZWD1V
Not sure on flow, just know its better for boost than my Trickflow R.
I was orginally going to get a box upper for my TFS-R intake
but they cost just as much the Super Victor intake.
This way will actually be cheaper than buying a box upper after I sell my TFS-R intake w/ rails for $400
Did it come w/ gaskets? Didn't see them listed. The only other thing I wonder is the difference in the port openings at both ends. The intake side looks much smaller than the t/b side
Oh and are these the rails you're talking about
http://store.summitracing.com/partde...p;autoview=sku
I measured it, its 3.5" (90mm) opening all the way thru
it just looks a little wierd since it transitions into a square.
Huge opening
No gaskets with it, uses standard TB gasket and standard 4150 carb gasket
Summit lists the mounting studs for the elbow to intake in
its suggested parts area with the intake.
Yes those are the rails, you need them for proper mounting
on the Edlebrock intake. Regular 5.0 rails wont work due
to how they mount.
There is also no provision for PCV vent. so you have to
go to valve cover breathers or header evac system
Huge opening
to how they mount.
09-01-2015 08:16 PM
