Starting Issues.....Any Sugesstion??
I own a 94 GT, and recently I was out taking it for a drive. I drove it for about an hour or so before returning home and shutting it off. I went to start it about 20-30 minutes later and absolutely nothing happend, including the fuel pump not engaging. I checked the fuses and they were all ok, so I was wondering if anyone knew of any possible solutions to this problem. I've heard of some kind of reset switch, but I'm not sure where this is located; if anyone could let me know I would appreciate it. Thanks,
Zach
Zach
RE: Starting Issues.....Any Sugesstion??
Check all your battery connections first and it's called your inertia switch and it's located on the passenger side kick panel underneath it but I doubt thats your problem they really only go off if theres an accident!!!!
also check your fuse box, move the fuses and see if the fuel pump engages, sometimes there is a loose connection with the fuse and the wires, happened to me once i replaced everything only to find out there was a loose connection with the fuse .
dalefrancis88
09-11-2015 07:15 AM
