getting that red stripe off!?!?!?
how and the heck do you get that red stripe that goes around the white fox bodies??? i took a razor blade to it the other day and it just comes off in like 1mm tears. its very aggravating. i'm trying to do it soft enough so that i won't chip off the paint. any ideas???
thanks,
jeff
thanks,
jeff
RE: getting that red stripe off!?!?!?
try using a heat gun. Just keep it moving because it will bubble paint up...I learned that the hard way. Or if you don't have access to a heat gun, 3M make a good adhesive remover that might soften them up a little bit.
ORIGINAL: philthy89fifty
the moldings on the door will be a pain depending on how well the car was taken care of. my stripe fused with the rubber and i was not able to remove it.
i'm thinking mine might be fused on there. it just didn't seem to want to come off. the plane was to get it off, then get those sticker things to fill in the mustang gt on the ground effects with black stickers. i know, i'm badass.
anyway, anyone else got any ideas???
I just took off my sky blue stripe last week. I used a hairdryer to get them off, it took a while, then I had to get the sticky stuff off too.
On the door molding I used a heat gun, it was really hard to get it started, but once I got it going, it peeled off in 5 seconds.
good luck!
good luck!
jwog666
12-27-2021 08:09 PM
10-01-2015 05:13 PM
