Wheel Spacer?
05-11-2007, 11:10 PM
Wheel Spacer?
'94 GT Coupe, 245/45/17"
I want to bring the rear wheelsOUT with wheel spacers (match the front profile and be parallel with the rear quarter panels)
Any suggestions?
.5, .625, .75, .875 or 1"
Any dis-advantages doing this?
Thanks for your help.
usapony
05-11-2007, 11:13 PM
RE: Wheel Spacer?
you'll need extended studs to do it properly
05-11-2007, 11:18 PM
RE: Wheel Spacer?
didn't think of that little important detail.
thanks
05-11-2007, 11:25 PM
RE: Wheel Spacer?
the eibach 1.5 inch spacers have studs built into them they should put the tire almost flush with the quarter panel
05-11-2007, 11:29 PM
The Rogue Mod
RE: Wheel Spacer?
Not a fan of big wheel spacers. Are these going to be for existing wheels or are you buying new ones?
RE: Wheel Spacer?
western pa?
i grew up there (grove city / slippery rock area)
you close to those?
05-11-2007, 11:32 PM
RE: Wheel Spacer?
just bought new tires and rims
stepped up from factory 255/60/16"
why aren't you a fan of wheel spacers??
05-11-2007, 11:57 PM
The Rogue Mod
RE: Wheel Spacer?
Don't like how they make the wheels stick out. The right tire/wheel combo will compensate for that.
05-12-2007, 12:13 AM
RE: Wheel Spacer?
Quote:
ORIGINAL: notch5oh
+1 i had 1.5 spacers on the bak when i had my 17x9 inch rims... with 255 and it was mayb a centimeter from being flush....
the will add rotational mass so your rwhp will drop some do to the hp required to turn them.... not much tho... mayb a hp or 2... if that
05-12-2007, 01:09 AM
RE: Wheel Spacer?
dont mess with spacers, i work for a tire store and ive seen people loose wheels cuz the lugs back off, ive also seen this cutlass with a bbc shatter some adapters like the eibach ones
