351w tranny
351w tranny
i want to do a 351w swap but not sure what tranny, id like to get a new one something that can hold some real torque, i was thinking tremec butim looking for a 351w roller engine, dont have it yet just getting it everything together now so
whats a good tranny for a 351w fox swap, any input would help.
RE: 351w tranny
and AOD will be fine for a mild build, and a "beefed up" AOD will be fine for a more wild build. of course you can go the C4 route, which is cheaper to make stout - and there's always the C6 route but its doubtfull you need something like that.
if your really wanting a manual i dont have any advice for you - other than even though its fun to pop the clutch and roast the tires, a properly built automatic will outperform a manual with even the best of drivers.
RE: 351w tranny
You have a few options.
1. G-Force T-5 from www.astroperformance.com
This is a stock T-5 with upgraded internals for 500hp
2. Tremec TKO 600
Nice strong 600hp trans, shifts like stock and similar gearing
3. Tremec T-56 / 6 speed
This is most expensive but gives you the most too.
T-56's come in 400hp version and 600hp "Viper" version.
There are swap kits (basically an offset x-member) and bellhousing
for both the Tremec's and install is fairly straight forward with the swap bell and x-member
Personally I went with the TKO 600 and have been very happy with it.
2. Tremec TKO 600
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
