Please help me reach 300 rwhp
Okay, here's what I already have and plan to keep: 302 block machined and bored over by .030, E-303 Cam, Federal Mogul Forged Pistons, stock crank, stock rods, FMS 1.6 Roller Rockers (pedestal mount), MAF EFI
Here's what I have that I plan to replace: Stock Mustang HO intake, stock Mustang E7 heads, stock 19# injectors
I built this engine a couple years ago, and it has served me faithfully. I've got around 40k miles on the bottom end now, and it's doing wonderfully. I should also mention that this is in a 1987 Ford Crown Victoria with a race-built wide ratio AOD. My torque converter stalls around 2600-2700, and this engine will run through a 3.73 locking rear.
Money, to some degree, is no object. I do not, however, want to tear apart the lower half of my engine, so everything listed there stays. This car is my daily driver, but I occasionally take it out to the track, and once my suspension and braking mods are done I'd like to take it out for SCCA AutoX. Because I live in Michigan there is no emissions testing, so I've removed my cats, air pump, EGR, etc. I have a high flow exhaust system that is probably most restricted by my stock Mustang shorty headers. So basically I'm looking for some heads, an intake, some injectors, and possibly headers that can get me to 300 RWHP and still keep this power in a usable range in the street. I'd also rather not change out my camshaft as I really like the E-cam. Whatever setup I get will be professionally dyno tuned/chipped. What combo would you guys recommend?
Oh, here's a pic of the beast in question (minus bumpers, which are normally on):
RE: Please help me reach 300 rwhp
ORIGINAL: 4fit?
Edelbrock intake, AFR165/185 heads, 1 5/8" longtubes. Might get you damn close to 300 rwhp.
if you are makin a setup that is just barley makin 300... dont get 24's, now if you plan on getting more rwhp out of it later, then go for it... i'd get 24#'s if i was you and had the ;money... coz i'd be getttin closer to 350rwhp with some afr 185's and a f cam or somethin
the AFR heads would be a good choice, size depends on the pistons you have and the size of the valve reliefs. if they are big enough, go with the 185 non emission heads with the larger 2.05 valves for better air flow. get some good 1-5/8" equal length shorty headers and hook them up to your existing exhaust which I hope is 2.5" diameter from the headers back to the tailpipes. the Edelbrock Performer RPM intake with a 75 mm throttle body, 24# injectors with adjustable fuel pressure regulator, and 80 mm MAF calibrated for the 24# injectors should be getting you where you want to be with it.
ORIGINAL: svt87
Good luck with the boat...er....project!
ORIGINAL: nemethjames1
ORIGINAL: roundman
