Door lock acuators
Old 05-13-2007, 02:31 PM
tmajikman
tmajikman's Avatar
Default Door lock acuators
Has anyone replaced them, and how do you remove them. Do you drill out the rivit or does it come out from the bottom of the holder inside the door?
tmajikman is offline
Old 05-13-2007, 02:59 PM
Legally_Blown
Legally_Blown's Avatar
Default RE: Door lock acuators
I was wondering the same thing cause mine dont work either.
Legally_Blown is offline
Old 05-13-2007, 03:04 PM
tmajikman
tmajikman's Avatar
I took the panel off the door, but I don't see how they come out either.
Old 05-13-2007, 03:08 PM
dj1203
dj1203's Avatar
i know in my sn-95 i i was able to remove them from the bracket that was riveted to the door without breaking the rivet, its a pain but you just spread the two side pieces of the mount enough to slip it out.
dj1203 is offline
Old 05-13-2007, 03:10 PM
tmajikman
tmajikman's Avatar
O.k., I will check that out. Thanks
Old 05-13-2007, 03:11 PM
Red FIVE O
Red FIVE O's Avatar
take of dorr panel
disconnect actuator
drill rivet from outside
there is a white clip that is held by the rivet inside the door that clips the the actuator
then put on a nother rivet.
(iv done this about 4 times on each side on my car)
hope that explaines
Red FIVE O is offline
Old 05-13-2007, 03:15 PM
tmajikman
tmajikman's Avatar
so I can't seperate or spread thewhite clip apart and just get the actuator out like mentioned before. does the new actuator include a new clip.
Old 05-13-2007, 03:21 PM
ponyboy88
ponyboy88's Avatar
best bet is drilling out the rivit, but you need a serious rivit gun for the new ones, the 50 resto kit doesnt come with the clip if i remember correctly,
ponyboy88 is offline
Old 05-13-2007, 03:23 PM
tmajikman
tmajikman's Avatar
o.k. thnaks alot.
Old 05-13-2007, 03:28 PM
nyfreakinrican7
nyfreakinrican7's Avatar
You should be able to just pull it off. I do it on my other fords all the time why bother drilling out a rivet when you can just pull and it come off? There are two white plastic bushings that go on either side of the door lock and they slide into a groove on the metal part that is riveted to the door just make sure you don't lose the plastic pieces
nyfreakinrican7 is offline
Quick Reply: Door lock acuators
