PLEASE HELP, i cant get it wet!!!
RE: PLEASE HELP, i cant get it wet!!!
its fuel injected... the gas pedal has nothing to do w. the injectors pulsing or not... its not even a gas pedal, should be called a throttle pedal, because on fuel injected cars, it opens the tb....
Check the fuel pump wiring, moisture can do funny things to electrical connections... check pump with a 12v direct power supply. Does the pump prime in the accesory posistion?
The spark plug idea is also a good one too... check those out... hope you use dielectric grease on all your plugs, wires, etc. in the future
Are you serious?? lol .. You really need to learn more about fuel injuected. And no im not a dumbass 86- on mustang have been fuel injected you obviously dont that if you car is turning over but lacks that intial spark where is your problem? your fuel..therefore you patting your gas pedal gives a little
09-08-2015 11:50 AM
gregsgt
07-03-2004 04:04 PM
