AC problems.. and summers coming
Hello, I have a 1995 convertable mustang GT 5.0 automaticand I can't get my AC to work. It doesn't blow out clod or hot air and the air that it does blow is only thru the defroster vnts on the windsheild. I have checked all of the fuses and I need some advice as to what I should look at fixing 1st. Could it be the blower motor or maybe a combo of things.
RE: AC problems.. and summers coming
it sounds like you have a vacuum leak causing everything to be blowing on the windshield. the no cooling problem could be a couple of things, low freon, or a bad cycling (pressure switch) ususally mounted near the receiver dryer. to check the switch disconncect it, it's only a two wire switch. jumper the two wires together and see if the a/c compressor kicks on, if it does then you probably have a bad switch, if it doesn't your probably just low on freon and possibly a leak!
M3hunter
09-05-2015 03:42 PM
