K-Member Manufacturers and ratings
I have a 91 5.0 and was thinking about switching over to a K-Member.
I was wondering do i need anything else. I was reading about the tubular A Arms and you need to get the coil over kit. Also it may move the suspension forward. I have the 5 lug conversion with the 94-95 Spindles Cobra brakes and wheels. Will this be a simple or many extra parts procedure.
Also is there 1 K-Member better than the other?
I was thinking of switching over now because the engine is pulled and am upgrading to a 347 stroker.
RE: K-Member What Else is Needed???
They make tubular k-members that take sn95 spindles, their are a both of different brands like QA1, MM, AJE, maxium motorsports are probably the best. you will need tubular a-arms, coil over struts suchas QA1, and the coilover kit. EBAY has a kit for like 650 without the struts, they are like 250 a piece
depending on what you want to do, there are many different choices. I would personally recommend the AJE racing tubular K-member and tubular lower control arms IF you plan on retaining your factory spring location. AJE makes a set of tubular arms that have a spring cup for the stock spring location.
If you plan on running a full kit, coil overs and all, UPR is the way to go. they cost a little less than the AJE racing setup.
And if you want a hardcore, ready for anything type of suspension... Maximum Motorsports has the most versitile setup.
I don't know how far you are in building your dream car But if there are other things that you have not done yet.....save the k-member for later.
Sure, it saves weight.....but for the price, you can invest in many other things that are much more fun.....
Haha I hear ya...well re did the entire interior basically all new, seriously New plus Flofit Fronts/ Matching rear Seats.NEw Stereo System,Just got the car painted. Just installed Cobra Brakes 13" Brembo Front w/ Cobra PBR Caliper and 11" rear with a 5 Lug SN95 Swap all the way around, Cobra Wheels, New Tires, New 3:73 w 31 spline Yukon axles, New Lower Torque Boxes withe S box Upper control Arm relocation kit, New Full Length Sub Frame Connectors, Brand New Upper and Lower Rear Control Arms, Brand New Tokico Shocks/Struts, New H&R rear springs, New Steeda Strut Tower Brace, New Trick Flow Heads anda 347 Being Built as we speak, New Tremec Tranny, New Aluminum Driveshaft( but switching over to Carbon)
So I want to get a sweet k Member that is really good, reliable, etc. w/ A arms and coil overs.
I think I am going to go with D & D...seems liek they have the right part.
Get a UPR Kmember kit ($699). It comes with EVERYTHING. You can run the stock shock but you have to do some work to it to get the adjuster sleeve/nut on it. I recommend a set of Strange 10way adjustsables or a set of QA1's. Can be done in about a day ( I took my time and was in no rush). You will also need some Caster/Camber plates. All in all you are looking at roughly $1000 after shipping and everything. Everything was included in the kit and i didnt have to buy anything other than two metric nuts to go on top of the strange struts. Here is a link to my work on my 85. Your car will be a little different but not by much at all.
https://mustangforums.com/m_3178882/...tm.htm#3183033
Tubular K-members are not the best thing for the street
they save weight at the sacrafice of strength.
check out the www.maximummotorsports.com k-member
saves weight and adds strength
