dropping out tranny need help.. have ?s
#21
RE: dropping out tranny need help.. have ?s
thats the stuff you need and by the way thats preety cool wit tha robots. i run automated welding machines on severe process related piping in nuclear plants all over the usa. our machines are basically robots only we program them from a console with video monitors as they weld in real time.
#22
ORIGINAL: iceman89gt
and how much oil... 3qt??? or just too
#23
get 3 but i think its only 2.5, you get the drive shaft out yet. just to give ya idea how quick ive had to do mine.... i got home at 3pm one day from work and dropped drive shaft, tranny mount, put new tranny mount back in,driveshaft back in, changed fluid in tranny, and oil and filter in motor. and changed throttle body out also. all that and was on the track racing at by 7pm that evening.but i do have a car lift. another tip for you, whenever you put tranny fluid back in rather than fighting it you can either fill it from the shifter or for later application after motor and all is in run a hose from the fill hole to the engine bay and put a funnel in the hose and fill it from there. its full when it runs out the side thats when you stop and once it stops drainingthe overfill then replaceplug and wipe it down.
#24
#25
make sure ur not working on it well its in Nutraul to lol, and using a extended ratch is alot easier to get them on done i hade to replace the drive shaft on one of my dads work truck for his contruction and it was not fun but a normal sort ratchet wont do it and u'll have to use small pipe and also block the wheels front and back. good luck
#26
ORIGINAL: Cleeman99
#27
being means i gotta stay up tonight all night cause i start working nights tommorow night i was gonna be here for ya but hell i guess i could tell ya what size all those bolts and nuts are tooo but thats all part of learning cause if i just tell ya you wont learn nothing
#28
#30
i can not get the bolts out of the rear end to get the drive shaft off... i got them soaking with Pinitrating oil (SP?) rite now... but they wont budge... even hit the ratchet with a hammer and everything and its not moving at all it seems
