94 cobra engine
94 cobra engine
I just installed a 94 cobra engine into my 95 convert with an aode. The computer is a 94 unit for the aode, 24# injectors. I also installed a 70mm bbk throttle body, a c&l 76mm meter and inlet tube with K&N, a 155LPM fuel pump. The engine runs great and pull real hard abov 3,000 rpm, but it feels like it revs slow and is slow to idle back down. Is this normal? The timing is aroud 13 deg. Thanks.
RE: 94 cobra engine
might wanna check your tps, make sure its at .98 or so... and make sure your throttle body is clean.... and check timing, maybe go to 13-14 BTDC, just run premium........ might rev and decel better if those are alright
RE: 94 cobra engine
you would be better off installing an adjustable fuel pressure regulator so you can adjust the fuel pressure with those larger injectors.
also pull and clean the IAC on the side of the throttle body as this has lots to do with how the engine idles.
11-10-2015 11:39 AM
09-08-2015 06:25 PM
