9,000 RPM 5.0L possbile?
#31
RE: 9,000 RPM 5.0L possbile?
Does meth injection help extreme NA motors?
Are there any good crate motors out there that are more or less NA monsters?
Also, my biggest reason for asking this question, is I want a Fox build up this is diffent from the norm. There are plenty of huge horsepower turbo'd/supercharged/nitrous'd street cars. But a 5.0 NA monster that can rev high, or a least make ~500+HP is different.
#32
well the biggest crate motor i found had 450hp and it was a 347 stroker from ford. imo they wanted too much. you can build ur own and save alot of money. yeah methanel injection helps with high compression ratios. do a search on this site for it and u should find some info.
#34
yes, will take LOTS of money in the valve train and rotating assembly to spin over 7,000 rpm.
you can do 7,000rpm "relatively" cheaply and streetable
cars running cams that do 10k, are idling at like 3,000rpm
never gonna run the street.
#35
ORIGINAL: BlackLX
1000+hp N/A on pump gas huh?
Lol, he posts alot at the banned site.
ORIGINAL: dimebag
and i no there are 1000hp+ sbf's that run on 93... you see it in 5.0 mag. all the time...
ORIGINAL: HC_CrAzYHoRsE
i've never seen any N/A 5.0s put out 600hp and run 9s before at 7k rpm, got any links to some buildups?
09-17-2015 07:32 PM
