turning flywheel
RE: turning flywheel
ORIGINAL: dimebag
right, see id like to do it, but the situation isnt allowing it, hell im getting a quadrant and cable in a week or two, not right away, again because of $$ issues. i had to borrow some from the rents to get the clutch, simply because my clutch is THAT bad... i cant go up hill in 5th, i have to drop 4th, and every gear, i have to feather...i forget what doughnuts and burn outs are, lol. all cuza some damn cops catchin me in the wrong place at the wrong time(60 in a 50, no headlights(long story), and speed exposition(wot thru 1st and 2nd, sideways round a turn)... all with in a week and a half.....
see if the mechine shop already has one done for your car. tell them you will just give them yours for one thats already turned. this way maybe they will give it to you on saturday and monday you can bring them your old one.
ORIGINAL: Swirl
I had a problem with my gears and it ended up just beign the cable that needed to be replaced.
ORIGINAL: dimebag
ORIGINAL: dimebag
thats not my problem, i can adjust the cable all i want, im 100% sure its the clutch.... i launch on mickey thompson DRs on a stock clutch... the enguagement point on my clutch is fine, but its just shot, dont worry, i no my manual tranny shyt... its the clutch...
ORIGINAL: Swirl
ORIGINAL: dimebag
I ended up finding out the previous owner tried to spot weld the quadrant section back together and that left me stranded. I am trying to find a new clutch pedal assembly (ebay is your friend). That should fix my problems all together. I was dreading having to get a new one. I have no idea how to fix it, but I guess I would learn, good thing it's not my DD - :P
where do you live? if your anywhere near DE, theres a local street racing forum im on a good bit... lota foxbody guys, im almost positive someone has a pedal assembaly on there...
ORIGINAL: stang8689
whats this other forum i live in DE
yeah dude if its not destroyed you can get away with not resurfacing it - just use the scuffy wheels or a sanding block or whatever ya got to knock the slick finish off it. actually a sanding block with fine grit paper would be best cause those little abrasive "cookie cutter" wheels will leave your once flat surface nice and wavey
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
junior04
09-28-2015 10:53 AM
logan409
09-26-2015 07:43 PM
