Submit Your Custom Cam Specs
#21
RE: Submit Your Custom Cam Specs
ORIGINAL: my77stang
yeah?
well........ oranges > apples
yeah?
#22
thats like sayin **** > a$$ .... and noone can really make that call lol...
#23
Don't forget there's more to a cams worth than simply peak numbers, peak numbers are for dyno queens and ricers....AVG HP and TQ...that's where the fun is. Give me BROAD strong HP and TQ curves on the street ANY day over peak numbers...majority of the time my tach is under 2500 and THAT'S where I want to drop the foot and get planted. I always see the peak numbers mentioned...guilty myself, but you want to see what the combo has look at the AVG numbers. I chose my cam after a lengthy conversation with a popluar grinder, my OTS cam was aprox the same price as a custom but it suited my needs and was available at barely a fraction of it's true cost..it was the only OTS cam he recomended for my parts list. The combo was built for broad power curve, the peak numbers were simply a bonus.
#24
oh my god you fu*king pussies the dude is asking for cam specs if you dont have them STFU!!!quit givin him hell. he is right if the cams are 1 or 2 degrees off or a slightly diff lift/duration youll never tell the difference on a street engine. so many people on this forum are so full of sh*t thinking that $200 or $300 moreis worth the extra 5 horses you get. sure custom cams are the way to go if your constantly at the track. if your not always at the track custom cams area waste. if you want to throw the extra money away put it ina package and send it to me or hell ill give you my paypal but get real.
a fool and his money are soon parted
#26
ORIGINAL: my77stang
but remember joel your really giving anything away because its "custom" for your application so it may not work well for someone else.
ORIGINAL: my77stang
crane, comp, lunati, and others do tons of R & D to make cams they feel will work the best with most popular engine combinations.
This thread is pointless.
I used to feel the same way you seem to be thinking right now. Then I started doing some serious research. I don't mean getting on google and looking up cam specs with dyno numbers. I mean going through some automotive engineering textbooks. The info available in these books doesn't even fully explore all of the things needed.
The reason for this...
It is proprietary. Engine builders aren't going to give out info on 'how' to design a cam.
I wish you luck, but you are looking at things the wrong way...
jason
#27
all i wanna do is compare ANY custom cam specs on the engine specs it was designed for agaisnt the closest off the shelf bump stick i can find and see what the dyno sim says the differences are - in peak power, and in power curve. its a simple experiment but i cant seem to get one person to actually speak up, which tells me most people on here with a custom cam prolly dont even know their specs, for that matter coulda got an e-303 thrown in their motor and wouldnt know the difference[8D]
#28
ORIGINAL: my77stang
#29
ORIGINAL: my77stang
i was being sarcastic LOL, and anyways poon > **** or *** (we BETTER all agree on that)
Unless you're my77stang, in which case man *** > all.
HA!
#30
HELL NO!
quote]ORIGINAL: my77stang
in the name of science, research, and proving a point to myself and probabl other MF members - anyone with a custom ground cam please post your lift/duration/centerline so i can do some research.
Thanks!
*edit* i anticipate + .600 solid lift radical grinds used in straight up drag cars to be worth getting custom, but anything in the .500 - .600 hyd. street driver range to be a waste of money over choosing the best "out of the box" cam available for your application.
we'll know soon enough [8D]
[/quote]
Thanks!
[/quote]
