Fuel Pump Relay
Old 05-18-2007, 06:56 AM
phorr20
phorr20's Avatar
Default Fuel Pump Relay
Anybody have problems with the fuel pump relay or the electrical?
There will be days that the fuel pump won’t turn on when I turn the key/ignition on.
I’m not sure why, but it seems to do it when it's cold outside. I’ll come back the next day and it fires right up.
I have changed out the fuel pump relay already.
Thanks
phorr20 is offline
Old 05-18-2007, 10:40 AM
tmajikman
tmajikman's Avatar
Default RE: Fuel Pump Relay
check the ground wires and also make sure that you dont have any corrosion on your connections.
tmajikman is offline
Old 05-20-2007, 02:36 AM
jrhaden
jrhaden's Avatar
I just got that problem solved today.88-91 relay under the seat 92 and up it is behind the kick panel on the passenger side and there is one under the hood by the MAF. Make sure you check youre fuse and inertia switch also.
jrhaden is offline
jrhaden
jrhaden's Avatar
Mine was doing the same thing and it was the relay under the hood.
jrhaden is offline
jwog666
12-27-2021 08:09 PM
b8checker
10-08-2015 12:55 PM
svfetter
10-05-2015 11:39 AM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel Pump Relay
