b&m pro stick with aod?
RE: b&m pro stick with aod?
a pro stick is a waste of money on a stock valve body. the stock valve body is NOT designed to hold 2nd gear......doesnt matter what shifter you use. i run a pro stick on my aod. there is a $50 adapter kit that needs to go into the tranny to make it work. the shifter arm on the side of the tranny and a couple parts inside must be changed to make it work correctly. i have a full manual valve body in my aod so the pro stick is a great shifter but on a stock valve body, dont waste the money. and if your running the stock valve body, you arent making any serious hp because it tells me your aod isnt built.
BeatnikFink
10-01-2015 08:00 PM
junior04
09-28-2015 10:53 AM
