Wobbling Balancer Followup *Video*
#31
RE: Wobbling Balancer Followup *Video
ORIGINAL: capri debris
Balancers are made out of TWO pieces... the center "hub" and an outer ring. There is a thick band of rubber seperating them. This band of rubber deteriorates over time and you will get a wobble if the outer ring starts to move around instead of staying in line with the inner hub.You havea bad balancer and it needs replaced... it can also give you inaccurate timing readings because the ring is not in the proper place in relation to the hub.
"Capri Debris" You were right! Check out the rubber ring:
#32
RE: Wobbling Balancer Followup *Video*
ORIGINAL: 5.0stanger
I have the napa one..works fine for me
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
