airbag steering wheel on an 87.
can i put it on by changing out the steering column itself?? i have the new wheel, and didnt realize till now that it wont go on. now, i dont need the airbag to function or anything i just want the wheel on.
RE: airbag steering wheel on an 87.
Not sure why you would want and airbag wheel on your non-airbag car but yeah the airbag column will fit in your car not sure the 87 column trim will fit it. If you have to switch to the airbag trim you MIGHT have an issue with the instrument cluster because the 90 - 93 cluster is different around the column than the 87 -89 cluster. I found that out when I put the 90 up cluster bezel on my 87 (to get rid of the useless warning light panel on the lower right hand side of the bezel) Air bag cars also have a different lower knee panel (bottom trim under the column) than the non-airbag but you should be able to use your 87 parts there.
if im not mistaken, the airbag equipped cars do not have a tilt steering column
ORIGINAL: preciousroy if im not mistaken, the airbag equipped cars do not have a tilt steering column |
my 91 has airbags and no tilt and lemme tell you it sucks! dont waste your time w/ that steering wheel and buy another one for your 87
ORIGINAL: preciousroy my 91 has airbags and no tilt and lemme tell you it sucks! dont waste your time w/ that steering wheel and buy another one for your 87 [IMG]local://upfiles/66563/DFB56E05748440DB9E976CC2CB00F5D5.jpg[/IMG] [IMG]local://upfiles/66563/9DE965BCFC4C4355988B19D2769435D3.jpg[/IMG] |
****, maybe yer right i just like the look of the 90* style way more....but no tilt= f that. by chance, i actually have the 90 and up cluster bezel...
