5Lug Fox Rear disc fitment question (turbo coupe brakes)?
nnnk'... This is my question. I have the aero & ranger axels, but, instead of all of those other brake set ups I have read about. I have brakes and discs from an 80's Ford T-Bird Turbo Coupe. It is all a direct bolt on, except the discs. Because the Turbo Coupe had a 4 lug rear end, the rear discs are drilled to fit my 5x4.5 lugs. Noone ever mentions on the net about using the turbo coupe brakes. I heard they are the same as a few pre 93 mustangs rear disc brakes. My problem is that I am wanting to get an upgrade in discs, but I dont know what will fit with my calipers. I know my front discs will use the SVO discs. But I wonder if I can use the SVO 5 lug rears? Or what about 93 5 lug rear discs? Are those two discs I mentioned the same?
RE: 5Lug Fox Rear disc fitment question (turbo coupe brakes)?
ah' never mind.... if this info is correct, I think this is all I need to know...
1. What you have:[/u] [blockquote] 79-82 All (except 79 V8): 9.15" front disc, 7.5" rear axle with 9" drums. 4 Lug.
1979 V8, 82-85 all (except SVO), 86-93 4cyl: 10" front disc, 60mm single piston caliper. 7.5" rear axle with 9" drums. 4 lug. 1986 GT: 10" front disc, 60mm single piston caliper. 8.8 rear axle with 9" drums. 4 lug. 1984-86 SVO: 11" front rotors, 73mm single piston caliper. 7.5" rear axle with 11.375" rear disc brakes. 54mm rear pistons, 5 lug. Rear is 1.25" per side wider than 87-93. Same rear brakes as the Lincoln Mark7s. 1987-1993 GTs and LX 5.0s: 11" front rotors, 60mm single piston caliper. 8.8" rear axle with 9" drums. 4 lug. 1987-1993 Saleen Mustangs: Same as the SVO brakes -- 11" front rotors, 73mm single piston caliper. 7.5" rear axle with 11.375" rear disc brakes. 54mm rear pistons, 5 lug. Rear is 1.25" per side wider than 87-93. Same rear brakes as the Lincoln Mark7s. There were optional brakes on the SA-10 and SC cars that used the Alcon 4-6 piston 13" front brakes. 1993 Cobra: 11" front rotors (larger hat to match the rear offset), 60mm single piston caliper. 8.8" rear axle with 87-88 Tbird Turbo Coupe 10" disc brakes. 38mm rear pistons. 4 lug, different offset from GTs. Rear is .75" per side wider than GT/LX" [/blockquote]
Shifty Magoo
08-25-2015 03:08 PM
carid
08-25-2015 08:17 AM
Fast-Hands
08-19-2015 06:54 AM
