Gear Problems
RE: Gear Problems
ORIGINAL: me alot fast than u
were the hell are you I'm in richmond as well..I know all about 12...who is doing the work on your car
RE: Gear Problems
if your using used gears there lies the problem..they have to be set up to run on the old pattern very time consuming but can be done with blue marker ink and alot of time..best thing is to buy a new set and have them install them for free and give you a credit on the gears you bought from them and cut your losses[:@]
RE: Gear Problems
They were supposed to do this the first time I was in there. Is there any chance they installed the wrong race/bearing sets?
This would really **** me off.
RE: Gear Problems
ORIGINAL: 90LX50
On the repair ticket they left in my cars said the bearing race was spinning in the housing. If I'm not mistaken, when you replace the bearings you also replace the races.
each bearing is machined for a certin race, so when you replace a bearing your supposed to replace the race too
RE: Gear Problems
I have a new pinion bearing an race if you need one....I think the owner is bob what an ******* I had to have a lawyer friend get all my $$$ from when I worked there did 10k of work in 30 days should had got 5k man give me a check for 2500.....took 3 guy to get me off his ***[:@]
