Fuel pump WONT turn on!
RE: Fuel pump WONT turn on!
it occurs quite often, i replaced one in both of my stangs and i hear about people having to replace them as well.After you've chnaged it out once I don't think its a reoccuring problem, but i keep an extra one on hand just in case.
i also want 2 mention i have no power to the red plug that plugs on 2 the top of the pump. SO the relay is probly bad i hope. I really want 2 fix this problem before the weekend or at least by friday
So you said you are getting power to the fuel pump relay connector under the seat, correct? Based on that fact and assuming the realy is good, this what you should try: First, check to make sure the red button on the top of the switch is depressed (just give it a push to make sure it isn't popped). If the switch hasn't been triggered or pressing the button didn't change anything then remove the connector going into the switch andplace a jumper acrossthe two wires to bypassthe switch.
EDIT: You can also jump the connector under the seat and bypass the fuel pump realy to rule it out.
The inertia switch was designed to "detect" a collision by messuring the cars inertia. The switch then cuts power to the fuel pump so you don't have gas pumping all over the place in a wreck.
