Fuel pump WONT turn on!
#24
RE: Fuel pump WONT turn on!
yep adder is right, once it has enough pressure in the line u wont hear it at all
ORIGINAL: AdderMk2
the pump will not run all the time... only when the car is running, or when you first turn the key
#25
remove it if u think its the isssue, i by passed it on my 93 cus it kept tripping. only 2 wires cut em and us a wire nut and connect em together
ORIGINAL: mustang5_0gt
could i just buy a new inertia switch
#27
Inertia switches don't go bad. You can reset them. Just push the red button to reset it. If it's not that then try the relay. But you really should have a wiring diagram and be going through the entire circuit with a dmm. Replacing parts is never a good idea. You'll just get frustrated.
TfcCDR
09-14-2015 12:08 PM
