does anybody use msd plug wires? i broke one...oops
yeah,i broke the damn boot in half!
i ordered a rebuild kit,but never messed with these
is there a trick how to bend them?
or do leave them straight?
RE: does anybody use msd plug wires? i broke one...oops
did you put them on then bend them? still connected to the spark plug i mean?
it's cold as hell here now so my hands were pretty clumbsy.
as long as they are not too close to the headers to burn them you can leave them straight. you can also bend them easily is you take out a spark plug and install the wire on it then carefully and slowly bend the boot in the direction you need it to go. look inside the boot first and see which side the connector is on and then make sure this side is on the outside of the bend and it should bend ok, just don't try to bend it too far or too fast.
thanks roundy....to make the bend you're talking about rib side out right?
which should be msd side out?
can i fix the one screwed up?
i took this one apart and it looked like i bent it right at the beggining of it.
i take i'm the first to break one huh?
