Crankshaft play- need advice
I just brought my car to a shop to have them check the vibration I've been having since I did H/C/I. Just to give a quick description of the problem, I had everything enginewise installed in my signature. It ran fine for 2 days, then after I did a burn out, the whole car started vibrating like crazy whenever I rev the engine. Clutch in or out, rolling or not, in gear or not etc. Well, after replacing the balancer, all clutch components with a new flywheel, checked the energy suspension mounts etc, it still vibrates. Well, they called me and said there is a little bit of play in the crankshaft and I have a slight rocker tick. They also said there might be other issues like the flywheel being off balance, even though its new, which I know is possible. I have a few questions. Can I have them replace the crankshaft and bearings and be ok as long as everything else inside is ok? Would anything else need replaced? What should this job cost? Could anything else be damaged? I didn't drive the car hard after the vibration started and I only drove it maybe 50 miles after that to get home and to the shop. Any advice would help! Thanks.
RE: Crankshaft play- need advice
They need to define a little bit of play. The crank is supposed to have some end play, or end thrust. As far as the problem.....uhhh? As far as what will cost what and what it needs, you need to find out what the problem is first. Are you sure the springs in the heads support the cam you used? Maybe you floated the valves and bent something?
ORIGINAL: 67mustang302
ORIGINAL: AdderMk2
i'd start looking into a new shortblock
That play could just mean mains have gone out of it... A crank kit will fix that, or just have yours grinded,just make sure you plastiguage everything before you put it in... While the motor is torn down, just have them to stick the flywheel and balance on and make sure its balanced...
ORIGINAL: kev2369
Also, when you put it all together, did you make sure your valvetrain geometry was correct... Check your pushrod lenth??? Adjust the rockers correctly??? Use hardened push rods???
