shifter vibration
05-22-2007, 12:49 PM
shifter vibration
In 5th gear at about 2k RPM and gets worse as i go higher, my shifter starts to really vibrate. I need a banlance and alignment but i didnt know if that was the problem.
05-22-2007, 01:01 PM
RE: shifter vibration
you should check your other gears at the same rpm and see if you get the same vibration if not it could be a problem with your 5th gear
05-22-2007, 01:34 PM
i had the same problem i had the steel drive shaft and it was vibrating to at high speed and rpm once i let off the gas it would slow down . so i got a ford racing drive shaft tha fix my problem .
05-22-2007, 01:59 PM
yeah it only happens in 5th gear....Hopefully a new driveshaft will fix the problem.
05-22-2007, 04:00 PM
Mine does the same thing but in all gears. I can hear the metal vibrating against the metal.
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
firehorse02
11-16-2015 11:28 AM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
50,
5th,
95,
fox,
gear,
mustang,
related,
rpm,
shifter,
slow,
slowing,
vibrates,
vibration
