How much power???
How much power???
How much power should i be at???? I have a 94 gt vert auto. with SVO upper&lower with a 65mm TB,CAI w/75mm MAF, UDP, Adj. FPR, LT headers, O/R X-pipe, Flowmaster 1-chambers dumped, and what should i run in the 1/4 mile. Just incase you didnt get it before it is a vert and a automatic. Thanks for the help. The car is still not running right im going to do a compression test on it tonight.
RE: How much power???
I'd be surprised if you were breaking the 200HP mark. Just out of curiousity, why get the larger MAF and TB before doing other things like heads, camshaft, etc?
As far as compression. I wouldn't worry about the numbes just yet. For now, just check all 8 cylinders and see if they are all relatively close to each other. if you have one that is way off (or two next to each other that are way off) then you know where your problem is.
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
