More Hp without more fuel...
RE: More Hp without more fuel...
he was if he had a tire... well, let me rephrase... if i took my car, added what he listed, ontop of the FEW things i have now, id run a 13.6 i havent touched the motor a damn bit
You don't need a 90mm MAF, that's just ungodly excessive. A 70-77 will do fine. Since the stock MAF is smaller than the stock TB, you will see a small increase with a larger one. Only a few horses, but it's something
ORIGINAL: FivePointOhh
wrong information. same hp....measuerd differently compared to previous years. and i would like to call bs on that last statement. if all it was...was a coupe and thats all you had and nothing else....you werent running a 13.6
The only weight reduction was I removed the amp and sub box.
Tires are not part of the equation here. It's on Dunlop 235 45 17's
SP902's. Left on idle with a 2.0 60'.
Also has long tubes and a pair of Flowmasters. I didn't bother to mention them because I'm confident they are not helping.
A few things I forgot to mention FivePointOhh. I have AC, 52psi in the tires, a full tank of 87 octane, closed throttle shifting like an Asian dude and shift points at 4800rpm.
Next time before you reply. Read some facts.
http://www.mustanggt.org/gtchange.htm
