SN95 help
SN95 help
Yikes I just removed the air tube that connects the heads (back by the fire wall), how doyou plug the holes I thought the holes were threaded [&:]???? also is it ok to cut the O2 sensor pig tails to add length?
Getting ready to fire up my 95 after installing bbk full lengths, X pipe , American thunder cat back, under drives, bbk cold air kit and tune up with motor sports plug, wires etc… ( and complete removal of the smog pump crap)
RE: SN95 help
dont know about the o2 lengthening i got a tune and they were shut off so i dont need them.i just read an article in one of the mags and they gave a tip for the holes.cut the ends off the tubes then turn them around and screw them back in.that should block the holes. good luck
RE: SN95 help
Thats great idea to turn them around...I was going to stop by a buddies and use his lathe and make little plugs that would be a light press fit into the ends to fill the holes. This will save me few hours, this is a temp item anyway since I will be buying a DSS 347.
