I think i may have gotten screwed on a head deal
RE: I think i may have gotten screwed on a head deal
I'm sure I could be wrong because I'm not that familiar with Trick Flow's stuff, but they look like a set of Twisted Wedge heads to me. How much did you have to give for them?
ORIGINAL: 94RedDevil
once we solve weather or not these are trick flows, someone wanna teach me how to post pics?
[IMG]picture[/IMG]
change it to this
[IMG]picture[/IMG]
I think, but dont hold me to this, all newer TFS heads have Trick Flow stamped or w/e at both ends, but in the older ones it didnt, if yours dont, you either have the older, and i think better, TW heads, or you just got owned
Does all of Trick Flow heads have this cantered/offset valve train or do they make an inline head. It reminds me too much of those valve eating BBC that alot of guys run around here.
YOU NEED TO GET THOSE HEADS RESURFACED!!!!!!!!!!!!!!!!!!!!!!!!
whoever cleaned them used a wire wheel/cookie cutter which means the surface looks like
^v^v^v^v^v instead of _________
and you can clearly see impressions from the firing ring on the headgasket. DO NOT INSTALL THESE UNTIL THEY ARE MILLED.
.................that is all
ORIGINAL: AdderMk2
they are definitly a twisted wedge design... but I need to see the whole head, multiple angles
someone could have owned you with a set of E6 heads... try to find a casting number
anyway they arent E6, my combustion chamber is more heartshaped
