B303 or E303 - Page 3 - MustangForums.com
Old 05-24-2007, 06:18 PM   #21
P Zero
P Zero's Avatar
Default RE: B303 or E303
Quote:
ORIGINAL: luckythirteen13
Quote:
ORIGINAL: P Zero
Quote:
ORIGINAL: Jasperstang308
its always recommended to upgrade the valve springs with any cam swap
Recommended but not required. Ive installed a lot of aftermarket higher lift cams with stock valve trains with no problems. My bro had a problem with his factory pushrods after he upgraded his springs, bent 2 in the first 10 minutes of running the car.
-P.
sounds like your bro was too stupid to upgrade his pushrods which is required when running stiffer springs.
He was inexperienced, hes not a car guy. I didnt do the install, and found out later about it. Of course he was too cheap to get a 90* fitting for his fuel line and started a fire under the hood . I've always run 1 piece hardened pushrods.
-P.
P Zero is offline   Reply With Quote
Old 05-24-2007, 06:21 PM   #22
PX429
Quote:
ORIGINAL: 5.0liter_rice_eater
if you have to use one of the two letter cams I'd go with the B303 + 1.7 RR
What the hell are you planning on doing with a 529 lift? Do you know what your saying?
PX429 is offline   Reply With Quote
Old 05-24-2007, 06:22 PM   #23
5.0liter_rice_eater
wait this is a BRAND NEW motor? Why would you thro that old junk on there?
5.0liter_rice_eater is offline   Reply With Quote
Old 05-24-2007, 06:24 PM   #24
gambit90lx
i had a b303 cam in my other engine but its blown and the car is in the shop right now my new engine has an e cam i am anxious to get my car back and see what kind of difference there is....i loved my b cam but i havent had anything else so i really cant compare......
gambit90lx is offline   Reply With Quote
Old 05-24-2007, 10:05 PM   #25
aode08
dont want valve float either
aode08 is offline   Reply With Quote
Cam and rear end gear questions Ryan Fitzpatrick New Member Area 3 09-14-2015 02:21 AM
Just Bought a Fox cema93 5.0L (1979-1995) Mustang 13 08-10-2015 09:35 PM
Cam choice help Redneck1465 5.0L (1979-1995) Mustang 5 08-08-2015 10:39 PM
Ford 302 horsepower goals mustangfan305 5.0L (1979-1995) Mustang 3 08-07-2015 11:09 AM
Camshaft Dilemma Obsol3te 5.0L (1979-1995) Mustang 12 06-19-2004 06:10 PM
b303, bent, cam, e303, flow, mustang, pushrods, recommended, springs, stock, trick, turbo, valve, valvetrain
Featured Sponsors
