351 swap
RE: 351 swap
It doesn't have to be expensive...
it just depends on what your goals are with the car.
Check out my site
http://www.freewebs.com/vristang/fox351wswapfaq.htm
for some of the details and options with the swap
good luck,
jason
Check out my site
good luck,
jason
RE: 351 swap
a 351w is a 351w
the issue will come down to $1000 in parts to swap it over.
Headers
Upper Intake Manifold.
Lower Intanke Manifold
Distributor with hardened gear.
Motor Mounts for a Convertible
Aftermarket Oil Pan
Engine Rebuild Kit, i cant stress this enough, any used engine should be torn apart and inspected/rebuilt by you, rings, bearings, honing, gasket packages.
dont let it bother you, all those extra cubes will put a BIG grin on your face
Headers
Aftermarket Oil Pan
