Went for my first drive in my stang!
Old 05-25-2007, 06:12 AM
BlessedHellride
BlessedHellride's Avatar
Default RE: Went for my first drive in my stang!
+1 I thought the same thing about the oil getting hot. WTF was he thinking? More than likely it is either the stater dragging or the timing being to high. You said it does it only after the car has been running a while and doesn't do it on a cold start. If it were my money, I'd bet on going ahead and getting a new starter and quit worrying about it.
BlessedHellride is offline
Old 05-25-2007, 08:52 AM
1990boostang
1990boostang's Avatar
Synthetis isnt always good dude. Its finds its way through seals and gaskets that normal engine oil doesnt. And what would oil have to do with your car not starting..LMFAO
1990boostang is offline
Old 05-25-2007, 08:53 AM
1990boostang
Synthetic**
Old 05-25-2007, 08:54 AM
creekrat
creekrat's Avatar
yeah, heat soak on the starter or timing issues. how many miles on the motor? Also could be worn timing components adding to the timing issues!
creekrat is offline
Old 05-25-2007, 02:40 PM
Foxbodyforever
Foxbodyforever's Avatar
The car has 216,000 kms on it which works out to... 130,000 miles? Anyway im going to try replace the battery and terminals first because i tested the thing today and it didn't have much charge.
Foxbodyforever is offline
Old 05-25-2007, 02:52 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Im almost positive its heat soak on the starter. Its really common with those huge *** starters on the older cars. I have a 93 so I got a mini, but I hear stories like this all the time. Give that battery a good charge and find yourself a mini-starter
WhiteFoxGT is offline
Old 05-25-2007, 02:57 PM
Foxbodyforever
well i tried charging the battery and it didn't do much, brought it up a bit but definately not to full [&:]
Old 05-25-2007, 02:59 PM
Foxbodyforever
what if i ran my car and then shut it off, hosed down the starter with some cold water and then started it again, think that would tell me if its the starter?
Old 05-25-2007, 03:16 PM
tmajikman
tmajikman's Avatar
you don't want to do that, you could crack the block, extremely hot, and extremely cold is really bad.
tmajikman is offline
Old 05-25-2007, 03:47 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
if it was heat soak it wouldnt turn over. its like a temporary seize on the starter. if i had to guess its the ignition controll module. notorious for going out on these cars when that dialectric gel gets all burnt up
FivePointOhh is offline
Nick Oliver
10-17-2018 04:22 AM
StalkerGT
09-25-2015 02:41 PM
96stang3.8
09-10-2015 06:42 AM
v8sn95
09-07-2015 10:17 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: Went for my first drive in my stang!
