What is your baseline tune?
Getting a poll....
1. What is your Timing set at? I am at 14
2. What is your Fuel Pressure at Idle? 38psi
3. What is your TPS at? .97volt
4. Where are your RPMs at Idle (stable or searching)? 900 (searching)
Needless to say.....I am having the popular, post-H/C/I Idle problems
RE: What is your baseline tune?
ORIGINAL: CantStopTheFox...
Wow...you are at 10-degrees too? I thought there is more performance at a higher timing?
you also have to understand that I run a stand alone EMU, that means I can set my timing to whatever I want... but I leave my distrubutor at 10° and have my trigger offset, set to match.
Only 10 on your timing? Why didn't youbump it?
ORIGINAL: PRO50SC
.99
900/stable
.99
900/stable
ORIGINAL: AdderMk2
not always
Do I need an IAC adjuster.....or a Diablo Chip with a Dyno tune.....(there is a place by me that does it for $400)
1. What is your Timing set at?16
2. What is your Fuel Pressure at Idle? 40psi
3. What is your TPS at? .90volt
4. Where are your RPMs at Idle (stable or searching)?700-1500 searching non stop
