Relocating Battery
RE: Relocating Battery
i ended up running a neg cable all the way back up to the block.
hey roundy why do you need to run a seperate wire from alt to the kill switch?
reason asking is i'm yanking my summit box,and making it right.
i'm running a powermaster,since it all ties into the silinoid,cant you run it just to the battery?
There are several ways you can do it, depending on the car. I just did mine last month, and it works fine. I used 1 ga cable from the battery to the starter relay and also from the battery to the unibody, and another short one from the unibody to the engine. If you are setting it up for the strip, you will need the rear cut off, and the alternator cable routed to the battery also to pass tech.
Here is mine:
http://members.tccoa.com/392bird/battery.htm
Here is mine:
ORIGINAL: 393Bird
Here is mine:
Here is mine:
JEESSSSE thats a nicw lookin car !!!!!!!!!! what kinda fan r u using? did u turn it upside down to hide all the wiring and the controls? thanks
Bobby:
Thanks, it has been a 2 year long, full time project so far. The fan is from a MarkVIII that I picked up for $30 in the junk yard. It pulls over 4,000 CFM. The wiring to it goes from the center of it towards the drivers side. The relays and temp control are remote mounted. Even with the 3500 rpm stall speed, the car has never gone over 185f in traffic.
Dont want to take up this thread, so posted a fresh one here:
https://mustangforums.com/m_330774/m.../tm.htm#330774
ORIGINAL: NegadivOne
Okay thanks guys. They sent a few of those tie downs in the kit but it looks like i will probably need a few more. I knew that to run at the track you had to vent the battery to the outside of the car, but is that a good idea to vent it no matter what? I wont get like poisoned or anything if i dont vent the box will I?
ORIGINAL: grabbem88
Well, nevermind everyone. My dad wouldnt let me do it because he said having the battery inside the car was too dangerous. So now i am out the $43 for the battery kit. I cant wait till I move out. I also got a ford e cam and my dad wouldnt let me put it in because he said i need to make sure i keep my engine reliable...
thanks roundy,it's just i have so many wires running through my car i was curious what my options were.
negadivone i think your dad doesn't know what's liable..........like your ignition switch known for many car fires.
i know that was out of context,but so is his thinking that an e-cam isn't liable?
logan409
09-26-2015 07:43 PM
