Strange.........
Strange.........
A few days ago, I got on the car pretty good. I was doing a 2nd gear dry burnout to be more specific. Shortly after that, I began smelling something like a burning odor. I had had a leaf get caught in my headers a while back and was thinking that it might just be that again. Well, several members of my club and I drove up to Tanglewood for the Festival Of Lights. we waited in line like 2 hours to get in and I smelled the odor periodocly. We get half way through the park and pull over at a restroom/concesion place. I go to start my car back and nothing happened. It tried to turn over and everything, but just wouldn't spin over. Acted exactly like a dead battery.
Well, I get security to come out with a jumper box and jumped me off. Car ran fine after, but I noticed on the way home that I was running like 10 volts max.
This has happened to me before. About a year ago, I sarted smelling a burning odor and had problems starting the car. I replaced the alt and the batery, just to come to find out that the negative battery cable was shorting out. Well, I looked at the cable this time. The main cable is fine, but that smaller gauge cable that ties into the neg cable apears to be shortin out. I haveb;t tracked it back to the place of origin yet, but I believe it is in there with the coil and starter relay somewhere.
Anyways, do any of you have any idea why I would be shorting this out? And why did it do it when I was romping on it pretty good? I am normally able to figure out almost any car issue, but this wone has me stumped. ???[&:]
RE: Strange.........
i was having some starting issues and I checked my starter, one of the long bolts that holds the starter together fell out, check the starter good, check that alt. again. Start the car and put a volt meter on the battery and make sure that it is @ close to 14 volts. If not its probably the alternator.
I think the coil is fine, but I might go ahead and replace it with a MSD anyway. It is currently an Accel coil.
But I will definetely check the starter.
Anyone else?
Anyone else?
ORIGINAL: 4fit?
???[sm=dontgetit.gif]
ORIGINAL: FoxGT
Now you've done it.
Now you've done it.
