Replacing the Clutch Pedal Assembly
Does anyone know of a good site that shows how to replace the clutch pedal assembly? I have one coming tomorrow that I won off of ebay and want to take out the old one today so I can just put the new one in tomorrow.
RE: Replacing the Clutch Pedal Assembly
you need to remove all the plastic trim under the column, then unplug all the electronics, then you need to drop the column down. after that, the pedal assembly will unbolt and pull out, assuming all cables and levers have been unhooked/unbolted.
I have gotten it about halfway out, but it's very tight down there to work - :P
I am hoping to have it done tonight or tomorrow.
Any pointers on getting some of the harder bolts out?
ORIGINAL: mattdel
lol, i imagine so. its not fun.
what was wrong with your pedal assembly to begin with?
So basically they decided to ghetto rig it instead of fxing it the right way.
[IMG]local://upfiles/50859/74794D74599A49FCB10108CD20268421.jpg[/IMG]
[IMG]local://upfiles/50859/18DB224BEFE94DDF96B5DE4FF71BD4B5.jpg[/IMG]
Here are some more pictures of my fun!
[IMG]local://upfiles/50859/72F007B40E16493C814648220C61742C.jpg[/IMG]
[IMG]local://upfiles/50859/A219412F4B2B4A599E15F6451F131554.jpg[/IMG]
[IMG]local://upfiles/50859/223ADCC11DC54AD6A9131E9BCF087C26.jpg[/IMG]
[IMG]local://upfiles/50859/75735D8C7CBB4711A4D63FD4B67A874C.jpg[/IMG]
ORIGINAL: mattdel
your gettin there. keep it up.
I really thought the cable would fix my issue and then I found this. It's odd though, the car won't shift when you first start it up and then if you drive it a few miles then it starts to work all of a sudden. I am hoping it's just the assembly and not the clutch that is causing the issue.
