Lean!!! UPDATED
Lean!!! UPDATED
So I scanned my motor tonight and I've got 2 lean codes 41 and 91 (left and right banks running lean). I've pretty much ruled out the MAF, tested it and swapped it for another one and I'm still getting lean codes. I'm going to replace the fuel filter tommorrow, it hasn't been changed in a year and a half. What else should I check? It seems that when sensors start going bad, they cause the motor to run rich, but that is not the case now. Anyone have any suggestions if the fuel filter swapdoes not work?
RE: Lean!!!
Things suggested to check:
- Vacuum leaks (do you have an open breather installed with a functional PCV valve?.....if so, there's a vacuum leak)
- Fuel pressure (with and w/out vacuum line connected...should be over 35 psi)
- HEGO ground wire condition and contact behind driver's side cylinder head (Orange colored wire)
- Exhaust leaks
- PCV Valve
- O2 sensors
- Exhaust leaks
- PCV Valve
- O2 sensors
RE: Lean!!!
The codes mean the O2 sensors are getting a reading outside what they are supposed to get. This can be caused by other things as well as bad sensors! Do not replace them unless you are sure that they are defective bu ruling out everything elce! Unless you just want to throw parts at it and hope that one will fix the problem!
RE: Lean!!!
ORIGINAL: Joel5.0
- Exhaust leaks
- PCV Valve
- O2 sensors
- Exhaust leaks
- PCV Valve
- O2 sensors
RE: Lean!!!
Okay so I got rid of codes 41 and 91 by moving my HEGO ground from my intake manifold, backto it's original location (on the back of the cylinder head), and replacing my fuel filter.My motor seems to be a lot more responsive, I can't drive it around right now though, it's been raining like cats and dogs and theroadsare waay too muddy. Now I'm getting code 45 which is a thermactor air upstream. What would trigger this one?
