Synchros Or Could It Be Something Else?
RE: Synchros Or Could It Be Something Else?
so a whole set of the synchros cost about 200? If i buy a 5 speed manual transmission rebuld kit for 250..they come in the kit don't they?
the kit dimebag is refering to is the one i use for my customers (and my own tranny) it's from ddperformance.com and contains all the syncros, bearings/races, orings, and the little odd and end things ie. roll pins, clips etc.... 210$$$ shipped is what it costed me when i did my first one (my tranny) the prices are the same shipping may very (not sure if they do flat rate shipping or depending on distance)
so what causes your syncros to actualy get ruined? and also what is a way to "save" them or keep them intact longer? I talked to a tranny guy and he said put gear oil in my tranny....60% dexron 3 and 40% gear oil....have any of u heard of this? thanks
Bad Bad Bad advice go kick that tranny guy in the *****... syncros are designed to wear out, they last on adverage about 100,000 miles + in moddern cars dad has a 86' chevy that is only used to towing things and the tranny is still original and no problemes with the tranny at all (211,000 miles motor was rebuilt) the only real way to get syncros to last longer and still beable to drive the car spiritedly (sp) is to use a high quality fluid
ORIGINAL: Streetracer911
I had that problem except my grinding noise was minorthroughout all of the gears. I replaced my clutch linkage with a steeda piece and it has been fine ever since. urs sounds like worn syncros because of a poorly adjusted clutch.A poorly adjusted clutch cancause gear clash whicheventually damages ur syncro teeth. Try adjusting ur clutch before u do anything that will cost u a lot of money.
spederman
23
03-07-2005 10:52 PM
