removing factory alarm
Old 05-29-2007, 11:39 PM
stangman94
stangman94's Avatar
Default removing factory alarm
CLIFF NOTES: Alarm is causing my car to shut off randomly how do I remove it.
FULL STORY BELOW[8D]
Lately my volts have been goin nuts and every now and then my car will shut off and start up while I'm driving. I can drive through it but it randomly comes and goes but not that often. I thought I had a bad ground somewhere but couldn't find one and I tested my alternator and it was fine.
When it did it today I brought it home and shut it off and when I tried to lock it. I noticed that it locked really weakly. So I tried starting it and it wouldn't. Then my alarm started going off but sounded real quiet. Then when I tried disconnecting battery it started going off as loud as it usually would. My alarm was installed at a dealer when the car was purchased and I believe it's interferring with something and causing this. So how do I remove it? Is there a write up anywhere?
stangman94 is offline
Old 05-30-2007, 12:36 AM
stangman94
stangman94's Avatar
Default RE: removing factory alarm
Old 05-30-2007, 01:34 AM
creekrat
creekrat's Avatar
Did you check relays? could be getting a bad connection at a relay, or a poor ground.
creekrat is offline
BOB ROME
07-26-2023 01:54 PM
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
Quick Reply: removing factory alarm
