explorer heads
RE: explorer heads
Your headers should work fine with gt40's, but you'll have problems with P heads. There is lots of argument about whats better, but head to head, the P head makes more power overall unworked. But then you'll need P specific headers, and the sparkplugs are in very strange positions, kindof hard to get to at times.
RE: explorer heads
The P heads are made for torque, and also have very weak springs valve springs, so if you are going to get a set find one that someone has already worked so you dont have to spend the money on them. I used a set on a 354 stroker block in a coupe, and they were the weakest link. I wound up going with AFR 225's. For a mild build up to a decent build GT40P heads are ok. In my opinion working with GT40's and P heads the GT40 in aluminum are a lot better power builders.
RE: explorer heads
i looked up these heads on checker and there are two casting #s...which is better:
E6SE 132.99
E5TE;E7TE 173.99
I just looked up 97 explorer with 5.0 and it says american cylinder head, did they rebuild or new from chikity china?
E6SE 132.99
E5TE;E7TE 173.99
