need help with cam!
need help with cam!
monday i was driving my car (power braking) reving about 4500 rpm shoved it in 2nd(automatic) and it dies go to turn it over and it cranks funny get it back to the house pull it apart and find the cam snapped in half .so now i need another cam (it was a stock roller cam).i posted this on another site but all i heard about was for a custom grind cam from one of their sponcers but i cant really afford one right now(i've got 5 kids and live in florida)so help me find a cam that will work with this set up ! 87 5.0 bored 40 over hyperutectic flat top 4 valve releif pistons,gt40-p heads (stock form),1.6 roller rocker on intake,1.7 rollers on exhaust,old school torker 289 intake ,650 holly,c-4 auto trans with 2800-3200 stall,355 gears. this is something i drive maybe once a week on the street (just around the block) it will spend more time at the track once its done .
RE: need help with cam!
I have a used Stage 1 Trick Flow. I used it when it was new and it is in great shape. It has about 5000 miles on it. Your valve springs should be changed but other than that I think it would be a great cam. PM me if you are interested.
sometimes there is just bad metalurgy (sp?) i mean if this thing has been running ok for quite some time and BOOM camsnap its probably unrelated to anything else.
you mention being relativeley broke, i believe a B-303 will work with stock springs to get you up and going - but really you need a spring swap for anything you get and if your going to replace the springs then you wanna get a better cam than a B-303 anyways
matt, did she do that little thing with her tongue like she does to me?
