oil pressure
oil pressure
i have a 88 stang...i it has a semi new 5.0 enige in it with about 65,ooo mi on it...
well my question was...
is that my oil pressure gauge needle is about 2 notches up from the bottom....
i tested the sender unit and its fine...
i was just wondering where the oil pressure is suposed to be normally???....
in the middle??
in the middle??
RE: oil pressure
I had the same problem with my 88stang- I changed the sending unit and the guage still read only 2 lines from the bottom. Then I put an aftermarket guage in and that solved the problem--it reads between 25# and 30# at idle. If anything I would change the guage for a little piece of mind--but that's up to you. Hope that helps
RE: oil pressure
ORIGINAL: bobby
get an autometer MECHANICAL oil pressure gauge for sure.... this is also a good time to get some other aftermarket gauges..... you could get some a pillar gauges
RE: oil pressure
yah i had the same problem then i went out and bought a machanical guage and it reads normally now. i mounted it outside my car tho for the fact that i dont want pressurized oil running into my car.
RE: oil pressure
for what it's worth, my '88 5.0 with over 108,000 miles on it still puts out about 50 psi oil pressure when hot and at idle. I can't tell you where that is on the stock gauge as I disconnected it when I installed my mechanical Autometer gauge. If you are really concerned about the oil pressure, get a good Autometer electrical gauge and install it in place of the stock gauge. They make gauge mounts that will fit into the center AC vent or on the A-pillar and are easy to install.
RE: oil pressure
yea i was thinking that it could just be the stock gauge...
so im going to pick up a autometer gauge somewhere...
anyone know of a good online site that sells autometer gauges for a good price?..
and thank you for your guys's help...
