Track Heat's, 1.7RR& E303
RE: Track Heat's, 1.7RR& E303
Sorry, I meant P/V clearance. The guy from trick flow said that if we use the upgraded springs (.600) that we would have to use the 1.7 rr's so that the springs wouldn't get damanged. He said it should be about .535 lift with the E303. Does this sound correct???????
.528 lift with a e303, take the listed spec (with stock 1.6 rocker) of .498 and devide by 1.6, that gives you .311 cam lift. multiply that by 1.7 for your new lift figures.
you are going to be very close with p/v clearance, its generally more a matter of duration. the e303 is 220@.050 and most people run into problems around 224@.050 .
why the e303 cam? its old school technology. if you have it i can see using it but why not use somthing that makes more power. as much as i hate trickflow the stage 2 cam would be a good choise for your engine.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
