Biggest SBF i have ever built.
#22
RE: Biggest SBF i have ever built.
yes i believe it will see 1500+ RWHP, its a F1-R procharger iam looking at, rated at supporting 1300 HP, strait from the manufacturer's site. the procharger will be MAXED out at 7080 RMP, my RPM limiter is going to be set at 7100k. with heads that have 258 cc intake runners, ported out to around 300cc, flowing 380CFM per intake runner, and a intake that can flow that much air, a cam thats desighned to build boost and has right around .700 inches of lift,a methanol injection system along with a intercooler toutilize the full potential of this blower while retaining a moderate compression ratio,not to mention winding it out to 7k RPM, where no part of the air flow and evacuation system will choke, i believe to see easily 1300 RWHP, and hoping for more.I have toyed around with the idea of adding a 150-250 dry shot to it [sm=nxsmile.gif], afterall i will beinjecting around 3-4GPH ofadditional methanol ( at 7k rpm full boost)to help in the cooling process, i might as well add some oxygen and burn it to. [sm=wootwoot.gif] I will do some more research in the procharger to see if it will handle it, if i dont think it will i will order a F-2 instead of the F-1R. If i do snap my 31 spline axles in my 9 inch rear diff, i guess i will just have to replace them with something stronger.
#25
ORIGINAL: anthros
a 1985 mustang GT, i still am looking at transmissions, i will be driving it on the street, so no power glide
subframe connectors, 12 point welded in roll cage, BUILT 9 inch rear end, up/lw control arms, built torque boxes.
and how exactly do you plan to hook up at the track?@!?!?!?![][][][]
#26
wow bro thats alot of mother F*&^ing power and i want all of it but i dont suggest on a 150 shot of dry i would go wet to be safe but i mean you seem to know what your doing so whatever you do go for it im not saying no but just keep it updated and im sure we all want tons of pics
#29
http://profile.myspace.com/index.cfm...endid=39527484
view the pics, its the red GT, the other one is my newer one
