novi 2000? or s-trim?
RE: novi 2000? or s-trim?
the novi 2000 is capable of a ton of boost. U will probably need to do a few more engine and suspensionmods before putting it on. It's ur choice, but if u have to have the blower id use the novi 2000 instead of the vortech s-trim.
no my cars suspension is fully done camber caster plates, koni full adjustable in the rear and steeda shocks and struts sub frames rear and front sway ported block headers bassani x pipe the cars fully done basically
what about ur axles, differential, and ring and pinion gears? Does ur tranny have a high enough torque rating to handle the power? If u answer yes to these questions then go for it.
