Small polish job, now it won't run well...
RE: Small polish job, now it won't run well...
ok guys, THANKS FOR ALL YOUR HELP!!!!!
i put the old EGR valve back on instead of that plate and it ran fine with it plugged in the electrical system.. its odd, but it works... thank god !!!
and thanks guys!!
and thanks guys!!
do i get any point for that????lol.since it's running ok did the polish job work any? or can you tell?
ORIGINAL: grabbem88
spray w-d40 back there see if it leaks?
i left mine on just plugged it up.
i hope it's something this minor.
wait till you see the pics, it looks mean as f-ck....
it isnt professional polish job but it took me 3 days and im very happy with it.. ill post lotta pics on my site tomorrow, STAY TUNED FOLKS.
when you block off the egr you need to buy this little resistor i seen somewhere that makes the computer think the egr is in closed loop. you had it open which the car didnt know what ot do
dont quote me but i think i found it on ebay. yea yea its ebay but i think i seen it there. was only like 15 bucks. something you could copy and do from say radio shack.
dbeck I was about to say something about a leak at the EGR valve area but you beat me to it. When I took my EGR valve off mine, I plugged the passageways in the upper intake with some marine epoxy compound backed up with some steel wool to keep the heat out of the manifold to keep things inside cooler. I also cut a plate to fit over where the valve used to be and sealed underneath it with some RTV also just to make sure it couldn't be a source of vacuum leaking. and just for grins, I took the EGR valve apart to see how it worked and all, the took the top part with the electical connection on it off and plugged it back into the wiring harness and tied it up out of the way and my engine idles and runs just fine without it. if you still want to take the valve off, this is what I would do to do it.
